HELP
Changed network route and computer
No way to work properly
The motherboard is broken?
HELP
If the network light isn't lit, that's a physical problem : The network of the gateway is not detecting a link. That's a separate issue to anything configuration related with your computer, etc.
First things would be to check:
If you still get no network light, it sounds like a hardware fault and would need repair.
connected switch hub and PC did not reflect
connected PC speed 10M not 100M
hardware fault Is it a motherboard?
