If I have my primary as an EOS TI and I want a ION backup will that cause any issues?
Or have people had better luck with getting a backup that is the same model as the primary?
The backup doesnt have to be same model - but they must be running same software version and the lowest total output count between both consoles dictates total output count in a tracking setup. For Instance, if EosTi has 4096 Outputs and Ion has 1024 Outputs, the Tracked Setup will only output 1024 Addresses.
ok thank you!
