Sensor Cem3 Dimmer: DHCP Lease fails
Hi
We have two Cem3 Dimmers (with redundancy) in use. Because of a network infrastructure change, I need to switch from static IP 10.x.x.x to DHCP.
But if I change the Cem3 the A device to lease an IP from our DHCP server, it does not get one, it falls back to I thinkg a self assigned 169.x.x.x IP. I also power cycle the device, with no change. The same change on the GIO console works perfectly, it leases correctly an IP from the DHCP server.
Does anyone have successfully swichted Cem3 to DHCP?
Thanks for any hint.
Best,
Norbert
t
