Hi all,
I’m having a very frustrating issue with all my sacn nodes dropping random universes when I am using PoE to power the nodes. I usually do get control back after a while but lose another universe somewhere else very soon after. (It’s not dropping whole nodes, just random universes)
the etc response nodes show “Data Loss Behaviour” error on the affected output.
the setup is: Ion XE 20 into a 16 port unmanaged PoE switch, out to 4 or so nodes (a mix of etc response and chamsys) through house patch points. Nothing else whatsoever is on the network.
The problem entirely resolves if the nodes are powered by other means than PoE, but for simplicity of setup I’d like to get this sorted.
The switch is a TPlink TL-SG116P
The issue is on every node, at every location around the building.
If it matters, I’m using approximately 3000 addresses across 10 universes.
any suggestions would be greatly appreciated.
