Ableton / Max4Live Devices to control ETC-EOS Lightdesks via OSC / Audio & MIDI
Hi there! I work as an audio engineer in theater, and I wanted to be able to control lights and lighting cues along with audio. I was really unhappy with the existing options, so I decided to build my own Max for Live devices.
If you are running a show with Ableton / M4L & ETC EOS, these devices might be just as useful for you.
Here is an overview of how they work. All of the devices share these core features:
  • IP Box: Enter the IP address of your ETC EOS lighting console here (Default: 127.0.0.1 / localhost).
  • OSC Port: Enter the network port you are using (Default: 8000).
  • Network Switch: Turn the network connection on or off. I recommend turning it off while writing automation to avoid creating chaos on the lighting desk.
  • "READY" LED: After loading the plugin into Ableton, it takes 2 seconds for the network connection to initialize. This intentional delay prevents an initial "network bump" from accidentally sending a CUE 0 / Blackout command to the EOS console.
Audio 2 CUE:
Write automations directly on your audio track to fire light cues.
Audio 2 Channels:
This device uses incoming audio volume to dynamically control the number of active lighting channels at 100% intensity.
It works perfectly with pre-recorded playbacks or live audio (simply route your microphone or audio group to the Ableton track and set the Monitor to "In").
  • Modes ("In-Order" vs. "rAnDOom"): Choose "In-Order" to create a classic LED audio VU-meter effect, or select "Random" to unleash absolute chaos.
  • Channel Range: Easily define your Start Channel and End Channel. The device will automatically scale and affect all channels within this range.
  • Sensitivity Slider: Adjusts how the device analyzes the incoming audio curve, allowing you to fine-tune the responsiveness from soft whispers to heavy transients.
Audio 2 Intensity:
Incoming audio volume increases and decreases the brightness of the selected light channels.
MIDI 2 CUE:
Trigger lighting cues effortlessly using MIDI data. You can play MIDI notes live via any external MIDI controller or launch MIDI clips directly from Ableton to automate your show.
  • Customizable Cues: Easily map MIDI notes to specific cue numbers on your lighting desk.
  • Flexible Triggering: Perfect for manual live performance or fully automated, time-accurate playback.
(I’m planning a 5th device, which will be able to control the intensity of lighting subgroups depending on the audio input.)
I created a YouTube playlist to show how these devices work. You'll find the links to the devices in the video descriptions.
https://youtube.com/playlist?list=PLncQeZQtdqQu_dX0nMN55j7fzwRsq9xh9&si=5A28vQo-zFrW5JBx
All you need to get this stuff to work is a computer with Ableton Live and Max4Live, an ETC EOS lighting desk, and a network cable. Some lights might also be useful (don't ask me about light, I'm sound! Wink).
I really hope this is useful for you and that you have a lot of fun using it!
Alex
I used AI to create this devices.
  • Just added another device. It can control your submaster depending of incoming audio.
    youtu.be/wSAQZ6XWeks
  • Hey Alex, relly nice work you did there. I was just starting to look for max with EOS when I found your work. That's a great starting point!
  • Hey taste, glad to here that!
    I made some updates on all devices and will upload them in the next few days. The port number was limited from 1000–9999, but I fixed it to 1–65535. I also made some visual fixes. If you're interested in the newer versions, leave me your email address and I'll send them to you.
  • Hey alex. I had the chance to look into your work. Nice one!
    I think I will try to build up on that. It would be nice to have an updated version of your plugins.
    As far as I have seen it the audio 2 intensity device blocks command input. That is unhandy and as you already developed audio 2 sub, which can do the same and more it seems redundant. But that's just my opinion.
    Further I thought it might be nice to share everything in a gitlab repo? That way it is easier to collaborate and build a sophisticated plugin library. What do you think?
  • You’re absolutely right. The Audio 2 Intensity device makes no sense anymore since there is the Audio 2 Sub-Intensity device. I deleted it from its online presence.
    However, there's the same problem with Audio 2 Channels—it blocks command inputs while it's running. I tried it with our lighting operator; you're able to enter GO commands to change the cue, but nothing else is possible. I have no better idea how to do it differently, so maybe I just have to deal with it. Or maybe the lighting guys will...
    Currently, I'm not a GitHub user. I’ll check it out when there is a little more time. In the meantime, I'll try to send a download link via DM.
