hi--
i've run into a problem configuring our 4 port Net3 ACN gateway with the GCE. our dmx outputs on the gateway need to layout as follows:
output 1 = 1-479
output 2 = 480-577
output 3 = 1024-1535
output 4 = disabled
i've had no issue configuring outputs 1 & 3, but configuring output 2 is where i'm having trouble. i'm sure its because i'm trying to bridge across dmx universes 1 & 2. i've tried to make a custom configuration for this port thru AIP in the GCE, but when in the AIP window, all options are locked out, and inaccessible.
hopefully this "lockout" is the result of something small that i've just overlooked? is AIP the correct route to take in order to set up this output for those dmx channels?
thanks!
steven maturno
associate lighting department supervisor
williamstown theatre festival
e: assoc-lighting@wtfestival.org
