Hey All,
So I am having a bit of trouble with a 4port GW.
If I set the GW to Net 2 mode. I can connect to it with a PC via NCE.
When I switch it to ACN I would expect that I could see it with the GCE in our Ion or the GCE on my laptop. I can ping the device from both laptop and console. When in Net2 mode I can also see the device from GCE and send it a command to switch to ACN, but then I cannot connect to it after that. I could use some suggestions. At this point we are having to work around since I cannot set priorities the way I want to. I deally we want to use the GW as a DMX merger since sometime wehave a HO3 come inwith movers and they want to run dual consoles.
Thanks for any help.
