I'm using the Analog IO as an IO Device for a QSYS system via the UDP controls.One thing I was wondering though, is there a method for polling the Gateway to get the current state of Inputs or outputs?Inputs seem to only send a UDP message when they are on or off, so the QSYS device won't know what state every input is currently in until it changes.Similar for the Output Relays, if other devices had told the Relays to be on, QSYS wouldn't know what those states were currently set too.Over time as it's an architectural controller, it will know all of the states, but if you were updating scripts or reload the design on QSYS, it would forget what the states of the Gateway were.
Hey Shadow20X6 this one is on our todo list but not in the current firmware. I totally understand what you're looking for though
Great. Glad to know it's on the road map. I'll look out for it.These things are dead useful for integrations.
