We have a show with a Show Control Midi Gateway, and i am getting correct Midi Notes send by Ableton, this worked before on other shows but nit know, the Gateway is on a switch and can be pinged and seen in Concert, Siftware Version is 2.1.0.10, Eos 3.0.2 Build 6, we hav list with Midi Notes that Trigger the cues, in the Gateway there a Midi can be seen as n/y changes.. the Gateway is connected with USB Cable..is there anything that has to changed that Midi Notes will be accepted, incoming Tab 99 only shows Raw Midi FF
thank you Hannes
from the firmware release notes for the Response MIDI Gateway:
Issues Corrected in v2.1.1:RSPWIDGETS-48099 MIDI Notes do not function
not sure if this will solve it but it might be worth a try...
Ok so we try that for the next shows, thank you Uli!
Ok Software update solved the issue!
