Temperature sensing in a Response DIN gateway.
Hello all,
I am currently drafting a Paradigm system design for a location with a high chance for reaching high temperatures in the environment. We will be using Response DIN gateways. The max operating temp limit for the gateway sis 40* Celsius.
Is there a temperature sensor in the Response DIN gateway? In the event that the temperature goes higher then 40*c, will the gateway be able to report back to a Net3 Conductor or Concert of the overtemp issue?
Many thanks,
