Mostly what it says in the subject line. I'm hoping I'm missing something obvious but below is what I've done:
- Tested different cables and ethernet lines to the lighting network.
- Done a manual IP address as well as the other selection options.
- Made sure that it is indeed connected to an lx network and not just getting power.
For some reason(when I set it to automatic) it keeps finding a "169.254.26.106" address that doesn't match anything that I know of on our system. But it still isn't working correctly when the IP address is manually set to the appropriate lighting network IP.
For extra context these gateways have been essentially plug and play for me in our other venue, and I haven't had to mess around with this too extensively with them before.
It's plugged into a rotator thats letting me know if it has or does not have any dmx signal. Everything is patched correctly in the console.
This isn't an emergency solve. But I would like to figure it out.
