I recently upgraded my network from running on net2/EDMX to Net3/replaced all of my wall mounted 2-port Net2 Nodes to 4-port Response Mk2 DMX gateways. However, we still have our 2 2-port Net2 Nodes (output) and 1 2-port Net2 Node (input) that I want to upgrade somehow and get it so that they are either the same as a Response Mk2 gateways or that are a Response Mk2 Gateway. Ultimately, I just want to be able to get them into concert so I can configure them if I ever need them. I do, however, understand that it's more complicated than just updating the firmware, so if it would be easier to just buy a 2-port response DMX gateway, I'm fine doing that as well, I just want to be able to save the need for all new equipment and to reuse the enclosure and hardware as much as possible. These are likely from about 2007, and I'm not sure how to even find them with the net2 configuration software (as far as what I've done without Tech Support's help), so I'm thinking the latter might be the only option. But if I can get them to communicate with Concert and not have to buy all new Response Gateways, that would be the best solution for now. TIA!
