Using a Response Gateway without sACN
I have a riser that was provided to me, an RSN-DMX4-DIN powered by a power supply. Two Questions that I feel I should know the answer to, but am brainfarting. And I don't have this piece of gear on hand to test.
1) Feeding it is DMX from an EchoTouch and outputting 2 DMX streams. This should work even without sACN and a network, correct?
2) The riser shows the EchoTouch and a standard XLR Input DMX signal from a console. I didn't think it was possible/recommended to use a gateway like a merger. Can you assign priorities to ports? I didn't think so.
