b113
In Patch: "Chan 381 Thru 388 Copy To Chan 12 Plus Show" is not undoable.
b113
Hi Paul, we tested this quickly and couldn't replicate it.
If you undid past that point, would it include undoing that command?
If you could try that, then pull logs from the Primary, we could have a look.
I undid to the last undoable command (Chan 12 Move to Chan 18) and it did undo the undoable command.
Logs emailed.
Thanks.
