Just getting around to updating the ion classic, found that starting in version 3.1.2 and carrying forward, the parameter count on the unlocked ion classic (or mine anyways) seems to drop from 6144 to 2048.
Sorry to hear you are experiencing troubles. Please provide your showfile and logs from this console. Feel free to upload them to this upload link.
I can't get logs for a little bit, the desk is out on a gig, it was happening across showfiles, including a brand new file.
Thank you for clarifying that it happens across showfiles. Once we receive your console's logs, we can investigate what is going on.
I’m also having the same issue should be 6k only reporting 1k. Dropped down to a earlier version of EOS works fine. Only tried 3.1.3 and 3.1.4 with deep clears etc all reports 1K
Can you please provide your showfile, logs from when it reports as 1k, and a photo of the serial number from this console.
If it is easy to accomplish; downgrading to a version that allows 6k output and saving logs would also be helpful.
