tried downloading the plugin into vectorworks and once i restart it, the plug in isn't there. any ideas why?
(first time using this so might be doing it worng)
ive just tried again and now its saying error with the script...
Can you post which version of Vectorworks you are trying to use and the exact error message it is reporting?
ive managed to get it to download now, just cant find the plugin now. 2022 version
Hey Seth,
So I downloaded the 2022 VW plugins, installed it through the 3rd party plugin manager on Vectorworks, but it's not showing up as a command on spotlight. I feel like for 2020 there was one more step, but for the life of me I cannot remember what that step was!
Did you add the command to your workspace?
Tools > Workspaces > Edit current workspace
Need to drag the command (under ETC) from the available commands on the left to a menu somewhere on the right
3th4n_c and Leadermans I wanted to follow up with you to see if you were still having troubles. I also reached out directly through PM.
