LED dimming
Hi
There is a question.
If you are using the dimmer rack of Senser + and Senser, I've used the same D20 module.
Old Senser Dimmer Rack in (CEM), dimming possible LED bulb that is now testing.
However, the use of Senser + (CEM +), flicker occurs. ( Between 1 - 30%)
I'm thinking dimming fundamentally the same module because it uses the same D20.
In this case, what's the differences?
Kani
