I have 4- ETC Smart Bars that have bare ends. I believe they were originally intended to be hardwired somewhere. Is it possible to put a connector on the end and power them off a distro? If so, what type of connectors do you suggest using?
Hi Nicoletta,
Are those Smart Bar1 or 2?
Can you let me know the Part Number / Serial Number? (In PM).
How many channels per Bar?
On The Bar there should be a total max load printed.
You can then put the appropriate connector rated for your country.
