Good evening.
I have a config mismatch problem in a rack SR 48
What did I do to solve this problem.
Good evening.
Hi Lamartine,
with CEM+ all the CEM+s in one Group share the same config. So if a Change was made to the config, when one of the CEM+s was not online, then it came
back online, it would have a different config, and give a MISMATCH config. The configs Need to be matched together again. Its best to contact your local ETC Authorized Service Center so they can help you get this back in order.
