Limiting available modules Cem3 setup
Hi
This might be a feature request, but is there any possibility to limit available modules in Cem3? Have Sensor3 racks with two different modules that we switch now and then, and the list of available modules in the setup is ever so long, a lot of scrolling to find the right one. I would like to be able to hide all the other modules from that list. Located in Europe so all of the US modules could be hidden as well.
Have the same wish for setup in Concert.
  • Hi Sivert,
    Thanks for the feedback. We are currently working on v1.7.0 of CEM3 which includes a filtering system so rather than just scrolling through the whole list, you select a type [Dimmer Modules] or [Relay Modules], for example, and then the list is much filtered down. 1.7.0 is currently in beta, if you would like to try it you can contact Greg who is our beta coordinator for that.
    https://community.etcconnect.com/members/gregthomas:1040:50
    On Concert - what version are you using? It should filter the modules to the European types and categorize them the same way, for example this is what I see for an ESR rack:
