DESISTI FRESNEL PROBLEMS
I have sent back 3 desisti fresnels for repairs this year with flicker and dimming problems...desisti told me that my dimmers need to be 'relays"...when i check the etc sensor 3 rack...the settings are R20....FIRING is normal...CONTROL is switched...CURVE is mod square and the THRESHOLD is 50%...using Cognito light board my address is 16 bit 2 dmx...not having any trouble with etc lustre 2 ellipsodials or colorsource spot with cyc lens... when i pull fresnel down from the light grid to test using just the settings in the fixture...i bring up the light through the 'dimmer' mode and get the same results not using the dimmer rack or light board...not sure what the problem is...thanks for your help
