Anyone
Does anyone have a cheat sheet for the cem standard module for set up and to Re-set
the device back to its default setting pre/going out ona show. Thanks Again.
Anyone
"Does anyone have a cheat sheet for the cem standard module for set up and to Re-set"
For Software Version 3.0 and Greater
Use these instructions to modify the rack type and/or dimmer modules that are used in the rack. These instructions should only be used if all of the dimmers in the rack are of the same type (e.g. D20s). If you have a mix of dimmers, (e.g. both D20s and D50s) you should contact your local service center to have the rack reprogrammed.
Caution
This erases all system configuration data. Do not run this test unless you have the Sensor configuration program and a copy of the system's configuration source file.
Caution
You can generate defaults only on racks that are populated with a single dimmer type. You cannot generate defaults if there is a mixture of dimmer types in a given rack.
Note
The default configuration will enable only port A with the first dmx address for the rack matching the unique dimmer number set in step 7. If your system uses port B (e.g. for a Unison architectural system), you will need to re-enable that after generating defaults.
Instructions
