I configured the CEM3 system of the sensor3 racks and changed the User fields in the setup.
Will these changed User- fields also change, when I use the TPSR App?
For example : Will the app show the DMX Address of the scanned Circuit, if i set up the user1 field to show the address?
Can not test test it right now, because the Hardware will be installed in spring.
