Hello,
how can i save a log file from CEM3 processor?
In setup, under file operations menu i see only option for save/load configuration and update firmware. Cant find log file
Thank you.
Hello,
Thank you.
Hi Nixtasos,
The CEM3 does not have a log file it keeps internally as such. It does log some information via Syslog, so if you have a syslog server (an ETC conductor, or other syslogging system) in your network you can use that.
What problem are you trying to diagnose?
-Tom
Hi, I missed some settings ( like switched mode, not dimmable) from some thrupower ETR15AFR dimmer/reley modules.
And I wanted to see how this happened suddenly.
I was very impressed because this setup has been operating for about 2 years now.
Thanks in any case.
