I have 4X 96 way sensor racks and due to phase balancing issues with the setup, the dimmers are not in sequential order. There is a soft patch within the rack making the field outlets numbered the way we need.
Is it possible, using concert software to be able to search for a dimmer number across multiple racks? This would be an amazing feature if it exists. That way i can search for a circuit and change it from dim to switch without having to manually search through the racks configuration to find the correct one
