Hello,
I am going to do be doing the lighting at a theatre that has Sensor lighting dimmers. They also use a Express 48/96 console.
I want to use my BlueLite X1 software/hardware to program the lights but for some unknown reason the Bluelite will not talk to the Sensor dimmers. I had this problem last year when wanting to use my Lanbox computer lighting hardware/software and never was able to make it work and gave up. I'm guessing there is some setting that is wrong in the Sensor dimmers CEM so they are not seeing the DMX signal from the BlueLite. So not sure if its a patch issue, I think its patched to universe 1 and it has a 1 to 1 patch. So I have no ideas. My BlueLite does work at our smaller theatre with different dimmers.
Anyone on here know if there is some kind of basic DMX setting that can be turned on? or if needed to turn off EDMX if it is on.
One other thing, the lights are set up on some kind of touch pad system so you can turn the house lights on while back stage or turn on stage lights while working on the stage (no work lights). Maybe it is doing something strange.
Please offer step by step information on things to check. The building is owned by the city so they know nothing about the stage lighting and the company that was managing the place does not know anything about the lighting hardware.
Thanks for your help.
David
