50amp Relay module
Good morning everyone.
I have a few 50amp plugs around my building. Presumably for when we had old cyc lights. Well, we don't use them anymore, and so I'm trying to get them repurposed for something useful.
Is there, or is there talk about 50amp relay cards? or CC cards? I guess I could just make that dimmer "Switched" in the rack, but I prefer an actual module in case I put some sensitive electronics on it.
  • You can read this from 10 years ago. To the best of my knowledge, ETC has not done a 50amp relay. And I do not think we will. But I'll ask around.
     50A Relay Cards?   50A Relay Cards?
  • Thanks, I did read that. But, again, it was from 10 years ago, so I didn't know if something had changed. Figured a quick ask wouldn't hurt.
  • I asked in Marketing and the answer is no. With everything moving to LED over the last several years, we are focused on smaller loads.
  • That's a bummer, I still have need for some bigger loads, but, thanks for the info. And thanks for doing some leg work to get an answer.
