DIMMER OR DMX FAN CONTROL
I need some cost effective ideas/products to control 6 fans. We have built an aircraft carrier exhibit whereby you are standing on the carrier as planes are taking off and landing.
I must be able to do wind "sweeps" as the planes move about the deck.
I am using a Medialon Showmaster ST
Any product or references if appreciated,
Gary
  • A DMX relay will allow you to control them from your Showmaster. Not sure what your fans draw so make sure the relay can handle the load.
    These guys have some pretty interesting stuff, I have never used any of it but.....
    http://www.bpesolutions.com/
    Then there is some relays made by chauvet and elation and those guys that are cheap
    http://www.chauvetlighting.com/pro-d6.html
    http://www.elationlighting.com/ProductDetails.aspx?Category=&ItemNumber=1412
    There are also DMX controllable fans on the market too. I wouldn't call them cost effective though....
    http://www.martin.com/product/product.asp?product=af-1fan
