What part number PowerCon connector should be used with a SmartPack? The literature does not list a part number for the connectors in the SmartPack or for the mating connectors so far as I can find.
•Standard output connection choices:
- edison, Stage Pin, twist-Lock®
- PowerCon® (mating connector: neutrik naC3fCB)
- 6-Circuit Socapex compatible (selectable off-set)
