Hello hope to get some help. SMARTBAR 2
Hello hope to get some help. I have two SmartBar 2's. Both have dimmers that will not come on and dimmers that will blow the lamp as soon as you plug the light in. Also one of the bars is flashing some of the working lights. Any ideas??? Thank you!
  • You should probably contact our phone support for help in troubleshooting this more directly: 800-688-4116.
    My first guess would be that the power input is not wired correctly. If a lamp blows that quickly, it's likely that you've got a hot connected where the neutral should go. That could result in either 208V (for 3-phase) or 240V (for single-phase) on the output.
