SmartModule 2 Advanced Menu
I try to change the menu option to the advanced menu, but it does not seem to accept the selection. When go back to check which menu is selected, it is back to the basic menu. I cannot access all of the settings I need in the basic menu. Is there a trick to change which menu mode is active? The setup and connect guide does not specify any special key command needed, and I cannot find an official manual for the SmartModule 2.
