Wanting to make sure I understand the Process for Switching an Address with a ThruPower Breaker in the Sensor 3 rack that was set to Dimmer. The intent is to add a Moving light fixture to this outlet.
1. On the CEM3 I selected the address & set it from "Dimmer" to "Switched". I also noticed the threshold was set to 50%. Without doing anything else When the ETC Ion board was powered on the outlet was not providing power.
2. I then Parked the Address at a Value of 100. which got the outlet powered up.
3. I also deleted the Channel that was linked to the Address.
1st question: Why do other Parked addresses show a value for Channel (100) & Param (Intens) When the one I parked does not. The other addresses are not patched to channel 100 either.
2nd Question: Could someone list their steps to switch and outlet from Dimmer to Switched & get continuous power when the Light board is powered up.
Is there something I'm missing?
Thanks for any input you can provide.
Jeff
