CEM3 Dimmer Rack
Hello,
I need assistance with an issue in the CEM3 configuration. One of the modules seems to be missing. Specifically, when I check the status of Dimmer 492, it doesn’t appear in the system. I can only see Dimmer 491 and Dimmer 493.
Could you help me figure out what might be causing this and how to resolve it?
Thank you for your support!
Best regards,
Marlon
  • What type of module is in 491? Some types take 2 slots. If you can send me the config I can take a quick peek
  • Hi Greg,
    Thank you for your reply.
    I just discovered that the missing circuit was located in a different space (see attached photo). After changing it, I was able to see the circuit. However, for some reason, the circuit remains ON. I tried switching it from Dimmer to Switched, but the state didn’t change. By the way, the missing circuit are 493 and 494, not 491 and It is a dimmer module.
    Do you have any thoughts or suggestions on this?
    Thank you for your help!
    Regards,
    Marlon
