Patching A Shehds Fixture
Hello.
I was recently gifted two Shehds LED Leko 250 W RGBW lights for my ASB, and patched them into EOS. When both are patched in, I can successfully change intensity from on at full to off only. When I turn them on, I have no control over color or anything else. It appears the fixture goes into some sort of testing mode, where it cycles through every single mode. However, the rest of the lights in the chain seem to work.
Any help would be loved! Thanks.
P.S: I am using the fixture that matched best in the most current EOS library.
  • Sadly Shehds has terrible documentation leading to all sorts of problems. But you'll want to make sure your fixture is in the correct mode/profile, depending on the specific model you have it might be something like 4 channels or 8 channels, etc., and of course, whatever you select on the fixture needs to match the profile selected on your console.
