Over Wattage & Over Voltage
I was asked to look at a 10 year old system that was blowing lamps. SR48, DR12, Express "bread & butter" school system.
The complaint said the worklights (but none of the stage lights) were going suddenly, as soon as the lights went on. 3 different dimmers, but all on the same phase of the SR48.
I found these 1000W lamps in the (non-ETC) work-lights, some Osram, some no-name. The 3 well toasted ones look like a severe over-voltage - just as the drama teacher said.
Now 3 - 1KW fixtures in a 2400W dimmer is bad news, but it shouldn't cause this. However, I couldn't find anything else wrong. The rack didn't report any errors, voltages nominal at both the CEM and at the fixtures. I replaced the lamps with 500W ones and everything seems fine.
What is happening?
  • I had the same problem with the 500W workers in one of our theatres, the lamps were lasting about a month before popping, relamping with 300W solved it.
    I think the problem was the lamps overheating.
    Cheers
    Richard
  • Any chance that the client had somebody with greasy fingers doing the relamping?  Given that it was a "school system," what are the chances that somebody who didn't know better (such as the janatorial staff) did the relamping with their bare hands?  Our clients regularly run 1K lamps of this type in 'mini-10' type fixtures with no problems.  The added heat of the 1K lamp is only going to hasten the problem happening.
  • Also, I am confused.  First you say that the lamps were on different dimmers but the same phase.  Then, you say that they were all on the same dimmer.
  • The lamps pictured show how they blew out, classic over voltage flash-out. The striping is where the filament supports caught the tungsten and shielded the glass. Fingerprint blowouts show a fairly obvious print location and don't usually have the tungsten coating the tube. There were only 4 lamps left in the fixtures (3 were empty) so they might have had other reasons. By the time it got to me it was far bigger than a stray student with leather gloves.
    As for the numbers; there are 9 fixtures total, 3 each on 3 dimmers.
    Over heating is unlikely to be the issue. These units have screen shields rather than glass so they aren't sealed up. Now when they closed the barn doors, thats another story. They also were burning out in seconds, so there wasn't time to heat up.
    I think I've covered the obvious, but it's always good to double check.
    [edited by: RickR at 10:49 AM (GMT -6) on Wed, Jan 26 2011]
