Hi guys,
I work for a church in AZ. We have a Mosaic system running one of our student rooms. There are 27 Mega-lite baby colors that wrap the room to add wall color.
We run the Mosaic control with 8 different presets. One of said presets is OFF... When we are in service we run shows off of an ETC Congo JR, this way we can have more control over the set.
The problem we are running into is.... When the Mosaic system is disengaged via the preset panels. Our ETC Congo Jr Is not able to interface with the Baby colors. What will happen is all stage and other lights on with mosaic fade to off correctly and are successfully controlled via the congo when needed... Except for the Baby colors, I have already checked to make sure the Patches on the Mosiac controller and The congo are the same... and to make sure that the Node that feeds the Baby colors is set to the Right universe (I don't think this would be the problem as the mosaic controller operates out of the same node and controls the baby colors just fine)
Hence the reason I am puzzled
Any help would be greatly appreciated.
Thank you,
