Hello all,
What are all the ETC equipment that allows me to collect energy usage data with the P-CCS.
Are third party energy meter compatible? If yes, what are the protocols and specs I should be looking for?
Many thanks,
Hello all,
Many thanks,
Shawn Fernandez - Care To Chime In.
You will need a P-CCS running software 4.0 or later. You can do calculated and measured power usage from ETC products. Things like a Sensor AF rack or Sensor IQ can provide that information back to Paradigm. Something like an Echo Feed Through Panel would be calculated.
System Components
The EchoDIN range is a new one for me. Is the Relay module capable of doing measured energy?
Hi Fadzil!
The EchoDIN range is indeed capable of doing measured energy management! I'm not sure where you're located in the world, but keep in mind that EchoDIN is only available for CE markets, not UL markets. However, if that works for you, then we'd be happy to chat more about what Paradigm Energy Management can do. Send me an email at Shawn.Fernandez@etcconnect.com and we can connect you with the right person here to help out!
-Shawn
