We installed HE Williams pendants that used OPTOTRONIC® OTi 55W Compact Programmable LED Drivers. They flickered intermittently when used with D20 modules even when set to switched mode. Switching to R20 modules eliminated the problem.
Hi Meierwj.
This makes sense. A D20 in switched mode does not fully eliminate the clipping that happens inside the choke with the sinewave.
An R20 is a true air gap relay and the correct option and glad that worked. Other options would be a CC20 or a ThruPower run as a relay.
ETC does not recommend using third party devices with a D20 in switches/non-dim load. Only ETC fixtures are tested and confirmed to work with D20s in switched mode without issues on the electronics.
LED Fixtures and Moving Lights Powered by ETC Dimmers - Electronic Theatre Controls Inc (etcconnect.com)
