Feature/Hardware Request - Inspire button station labels
Please make covers for the Paradigm Inspire button stations that are able to be labeled in the field, like the Echo Inspire button stations are. This would be an excellent option because
A) You would be able to use all of the colors that are available on the Paradigm version for the buttons, and,
B) Usually for installs, the client doesn't know what they want to label the buttons until after end-of-construction. It usually isn't practical to get them engraved and send someone to the field again to just give standard names, like the Echo versions have in the PDF template. So usually, you end up with tape and a sharpie label, or a label-maker label over the existing, which looks cheap.
