hello
my power failed and the lights/dimmers are locked on full from the last cue. the house lights and the lights/ dimmers that were not on respond fine. we have a unison system,ER dimming rack and a sensor+ cem+ 96 dimmer rack
hello
Hi.
Sometimes when the power goes out or a brown out happens to the power of the unison processor it holds information in the background. When this happens you have to go into the menus and run local zones off or all zones off. Feel free to call us at 800.688.4116 8-5 ctrl. and ask for phone support, we can help you work through the menus to find that option.
i used the reset button but it but i just came back up. with a dimmer error message that then went away and said it was OK
thank you
i will call thank you
DO be careful when hitting reset, because hitting reset twice in a row will cause the processor to skip loading the config into memory. All you have to do it hit reset....and not hit it again, and all should restore just ducky.
Its very useful when you have a corrupted config loaded....not so useful if you happen to find it on you own
