Hello,
i am not able to find any documentation on how to connect an EEB to a CEM3-processor in a Sensor3 rack.
For paradigm this is documented as it is connected by ethernet.
Are the two components connected through Ethernet, do i have to connect one bus of the bridge with the echo bus on the CEM3/Sensor3 backplane or do i have to connect both?
In addition:
is it possible to use lighting designer software for management of a CEM3/Sensor3 + Echo Expansion Bridge Echo environment or do i have to use the echo access app?
Thanks a lot!
Best regards
Mathias
