Hello,
We are looking to have separate fade up/down times for the Presets. Currently, it appears there's only one timing for up/down per preset. Is there a way to implement this?
Thanks.
Hello,
Thanks.
rlsound
There is currently no split time fade option.
However as a potential solution you could build 2 Presets with the same content and apply different fade times to them.
Essentially making a Preset X Up and a Preset X Down and then have two buttons on your screen. And I would label them as such.
Now technically it'll still be a toggle button so if you tap the Up again it will fade down.
Reversely you could also put an OFF button and set a different time for that. But that would turn everything off and not just deactivate a preset in case you had individual zones up still.
As a final possibly solution, but I haven't had a moment to try it out. If everything is in the same space or room, you could set a double tap function of a button to Space Raise with a Timing set. That should only ever raise the space. And then a second button of Lower Space with timing. Both on a double tap. It should work, but that's usually meant for a button station press, and I haven't confirmed it works on EchoTouch once it's configured.
Just so we know for future cases. What is the particular need for a split time, and how much difference in timing are you looking at?
Examples:
Echo Access possible solution:
Thanks Chris,
This is a Cinema, so the longer fade out is preferred ( 7 Seconds ) but on ramp up, we'd like 3 seconds as it's a little long to respond after triggering the preset.
The presets are programmed to a call station. The double tap will get me in trouble with the technicians as they are used to single button up/down as it is currently.
Well the off button may be your best solution then as I assume it's all lights going out in 3 seconds.
Or best to probably just do two presets and label it as such. The power of Suggestion! This one says down so it only ever goes down.
