Hi All,
When I configure my fixtures (turn off color temperature (No Function) and define a color) and save this to a new file, these settings are there if I reload the file?
What could be wrong?
Thanks in advance....
Bob
Hi All,
Bob
What I ment in previous post is after saving the fixture settings are NOT there after reloading the file. When I configure the fixtures and put then in a CUE it works fine (after starting the CUE). Could it be that configuring the fixtures, saving them and reloading them will NOT send the command s to the fixtures?
It sounds like you hadn't Recorded anything, so there's nothing to save.
Once you've set up your look on stage, it needs to be Recorded into a Cue or onto a Playback fader for later use.
Hi Richard,
I was expected that also all data in a show was recorded when you save it to a file, even when you haven't recorded anything. Thanks for your answer, I now do understand WHY ;)
