OSC command not working
I've been using the command /cs/key/ind2
I recently updated to 3.1.1.16 and it seems to have stopped working.
I was also playing with setting a playback slider to a level with osc.
/cs/playback/11/level/x.  I get no response from this command.   I do get a response from /cs/playback/11/fire/1
Thanks.
Mark
ColorSource 20AV
3.1.1.16
  • The OSC command should be /cs/playback/X/level = value (0.0-1.0)
    0.0 is fader at the bottom, 1.0 is fader at full.
    How you enter the value depends on your OSC application, most OSC apps that support faders have a Min Value and Max Value you can enter.
  • Hi,
    Indeed, I also have the impression that something has changed. I was also using this playback command, /cs/playback/11/level/x, which is documented, and which no longer works correctly.
    Richard, when you say that the command is:
    one should understand ? :
    /cs/playback/X/0.0
    /cs/playback/X/1.0
    Is this correct ?
    I use QLAB 3 to send commands, and am in 3.2 CS20AV
    Are the OSC commands documented on page 80 in the 3.2 manual up to date and working ?
    I don't think so !
  • No, the command is:
    The value or argument to send is a float between 0.0 and 1.0.
    If you omit the word "level", then the console doesn't know what to do with the number!
    Looking at the QLab documentation (https://qlab.app/docs/v4/control/network-cues/), it seems that QLab uses space-separated values.
    I think you would type the following into the box to send master playback #5 to full:
    /cs/playback/5/level 1.0
  • Ok Richard, Thanks. I will try your solution.
    What I have experimented, is :
     /cs/playback/5/fire/1, doesn't show the same result than push the playback flash 5,
    contrary to the documentation page 82.
  • Ok Richard,
    This string works with a space , and the level depend on the value 0.1  0.2  0.3
    0,1. 0,2 0,3 (also works with comma)
    BUT
    It does not do what  expected with a flash on this playback.
    If you can see my video here.
    It is the same with level 1.0 instead level 1
    CS20AV software version 3.3.0.22
