Change Color of a fixture in a Cue through OSC
I'll try to explain what I'm trying to do because maybe there is a better way to accomplish my goal.
I currently have a Stream Deck that triggers OSC commands to my CS20AV console. Primarily, I use the "go to cue" function to switch between three different lighting looks. In these cues, I have a couple of fixtures that I want to be able to change the color of through OSC. The issue is that the intensity value becomes locked when I change the color through OSC. Each of the cues has a different intensity value, so I don't want it to become locked.
I did record the cues using color pallets, so I am able to change the colors in the cue that way, but as far as I can tell, I can't change a color pallet through OSC.
I'm curious if anyone has any thoughts on this. Maybe there is a way to do this through playbacks?
