Update Chauvet Colorband Q3BT in the library. It's listed in the library as a 6 Channel when it's a 16 channel fixture.
es.chauvetdj.com/.../...
Hello. I just made a post about this exact fixture, I’m not able to find it in my console. Are you using the ColorSource 20? I looked through my console’s library but could not find the specific Q3BT fixture, you’re saying it is in yours?
Hello,
I am seeing the Chauvet Colorband Q3 BT strip profile in current ColorSource Console software (3.2.0).
Only the 4-channel and 6-channel modes are supported by ColorSource. It does not support multicell / multi-emitter control, which would be required for the 16-channel mode.
Thank you Matt, that’s very helpful to know. I was able to find this fixture after I updated the firmware and profile library.
I just wanted to make sure I was using my fixture at peak performance. I’m sure 6CH mode will work for what I need anyway.
