Parents Reply
  • Hi Richard,
    sorry i wanted to edit my post, now it gone...
    I used the wrong terminology.
    What I want to do is:
    - Playlist 1 (Show)
    -at Step/Sequence 7 goto Playlist 2 (Dance Act) Step/Sequence 1
    -at end auf Playlist 2 goto Playlist 1 (Show) Step/Sequence x
    I want to program different Playlist for single acts, due to constant changes of acts every day, so I don´t change the "core"-show everyday.
    Thank you for the fast answer of the last post.
    CU
    Jens
Children
  • Hi Jens -
    please check the help system/user manual for "action macros". You can embed commands on sequence steps in your main sequence that will start a sequence on a master playback. You could probably make a macro that just presses go on that master playback and then at the end of the sequence on the master (seq 2 in your example) that triggers the restore step on the main playback, getting you out of the go loop, if you know what I mean. If not, let me know and I'll try to write a more coherent response when I'm no longer on a train.
    Sarah
