How can I import show files made on an ion cosole into my Conge kid running Cobalt?
Ric said:It'd be great if Cobalt did an import directly seeing as it's an ETC desk as well.
(snip)
Perhaps for a future update this will happen?
Ric if you compare the philosophy behind the two desk, you will work out for yourself that this is almost impossible.... Cobalt does not work in degrees rather than in percentage of dmx-values. Also Cobalt is a preset based desk. It also has is roots in the Presto (AVAB) range of desks. Transferring shows between different console types will always have some limitations.
