hello i try to have the crossfader in master (for example 1 and 2) how can i do?Thanks
Hi there -
I don't understand what you are trying to do - can you provide more details?
Sarah
Hi there -
The main playback is separate from the master playbacks. To see a playback tab for a sequence on a master, use CONNECT & Master Key to connect that master to the "master playback controls". These are the playback controls in the center of the Cobalt 20 and 10 consoles.
Thanks -
Sarah
Hi -
Are you using a Congo jr by chance? In this case the master and main playback controls are shared so there could be some conflicts.
Thanks -
Sarah
