Hello, I have noticed bad bug on Cobalt 7.2.0 software running on Congo jr. When I make channel masters and save the show and when I turn off Congo then turning it on and resume, some masters are gone it is unbeliveable and frustrating. I work with cues in sequences and I found that channel masters are easier to work with than preset masters. I did not try work with presets in sequences maybe cues are problem but anyway it is bad. Any ideas anybody?
There is a setting in [Setup] called "Auto-update Master Page".
If that is not ticked then changes to Master content are temporary, unless you use [Record] & [Page] to store them.
I checked it, it is ticked. I think that problem is with sequences changed to cues, because I noticed that when I make preset Masters there is no text in Masters dock shown. Thanks for fast replay.
Ok, here it is. I made a show with cues in sequence 1. I put some channels in masters using [MASTER]&master softkey 10 and editing them in master directly. I made 3 such masters. I saved the show and turned off console. When i turned on console 2 of that masters were gone. I tryed again and after restart same thing happend. All masters that I made using preset [RECORD]&master softkey # are OK. Thanks for helping.
Yes the masters worked I used them in show. It is enigma to me that happened to me cuple of times in the past month. Only the channel master are gone on resume.
